What heads should I purchase to use with lingenfelter GT2-3 cam
Old 11-24-2006, 02:22 AM
marcdez's Avatar
Default What heads should I purchase to use with lingenfelter GT2-3 cam
What heads should I purchase to use with lingenfelter GT2-3 cam. Initially I was going to go with a bigger cam set up but I need drivability and reliability so I am going to stick it out with this cam for now until the motor is toast then I might as well get an LS2 but for now I am looking for the heads that will fit this cam the best. Thanks for any help on this.
Cam specs are 207/220 .571/.578 118.5 LSA Some people call it an LS6 cam on steroids.
98 six speed Trans Am
I have Ported TB
Cut out pipe
ASP Underdrive pulley
Clear air lid with K&N filter
Throttle body Bypass
Free Egr Mod
Ram air hood including the air box
SLP 160 degree thermostat
Cags Skip Shift eliminator
8.5mm MSD spark plug cables
Mac midlength headers and off road y pipe
NITTO Drags
lingenfelter GT2-3 cam and 918 springs.
Old 11-24-2006, 02:27 AM
marcdez's Avatar
I am trying to get as close to 380 rwhp as possible with this cam or more if possible.
Old 11-24-2006, 05:55 AM
PREDATOR-Z's Avatar
PP 243 Stage 1
Old 11-24-2006, 08:06 PM
marcdez's Avatar
Thanks anyone else have any suggestions?
Old 11-24-2006, 08:54 PM
mullenh's Avatar
you just got the best answer. if you did not know.
Old 11-24-2006, 11:42 PM
marcdez's Avatar
Ok so this is the 243 casting with the D port some call it an ls6 or an LS2 head is this correct? I just want to make sure I buy the right ones. Thanks for the help.
Old 11-24-2006, 11:56 PM
NviouSS's Avatar
yes. 243 castings=LS2/LS6 heads
Old 11-25-2006, 12:42 AM
marcdez's Avatar
Ok thanks for all of he help guys. I really appreciate it.
Quick Reply: What heads should I purchase to use with lingenfelter GT2-3 cam
