Need recommendation for turbo pistons
Old 12-02-2006, 09:39 AM
7 Second Club
Phil99vette's Avatar
Default Need recommendation for turbo pistons
Looking for:
4.005 bore
4.00 stroke
-25cc or bigger dish
6.125" rod
.927 WP
Just looking for some feedback on the JE/Mahle/Diamond/Lunati to find which ones are the best for 20psi+ boost.
Old 12-02-2006, 09:43 AM
sr71's Avatar
wiseco....2618 alloy, -32cc dish, rated for 25psi, 1/16" rings instead of those funky metric rings and $518 from summit. I believe the part number is k396as
Old 12-02-2006, 09:45 AM
The know it all's know it all
Sean Collins's Avatar
Mahle makes a kickass turbo piston. The other option would be diamonds. Diamond can build you a seriously badass piston most like a few grams heavier then a mahle but you will sleep well at night.
Old 12-02-2006, 09:48 AM
sr71's Avatar
the off the shelf mahle turbo pistons are 4032 alloy unless you buy the high $$$ ones from wheel to wheel. 2618 alloy is prefered for higher boost apps.
