View Poll Results: How much to shim the oil pump spring
.080
3
21.43%
.100
6
42.86%
.150
5
35.71%
shim it(post your preference)
0
0%
Voters: 14. You may not vote on this poll
How much to shim oil pump?
Old 12-03-2006, 10:11 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Default How much to shim oil pump?
I did a search and found 3 different answers.
Some say .100 minimum, LME supposedly recommends .150, TSP shims theirs .080. Which one is going to be best and not wash out bearings. Im going to fully port my oil pump with my dremel tool but I would like to bump pressure up a bit, I was at 65psi at 6600 and with my 4.100 stroke crank I want a little more lubrication and Im running large oil tolerances too, to help with the loading form the big stroke crank.
Old 12-04-2006, 06:12 AM
1slow01Z71's Avatar
bump.
Old 12-04-2006, 12:01 PM
1slow01Z71's Avatar
bump.
Old 12-04-2006, 05:20 PM
1slow01Z71's Avatar
lol nobody knows?
Old 12-04-2006, 07:34 PM
1slow01Z71's Avatar
I find it hard to believe that out of everyone on here no one knows what the general accept shim size is.
Old 12-04-2006, 07:47 PM
Ls2Sonoma's Avatar
volume is the key
why do you need more oil pressure??
Old 12-04-2006, 07:55 PM
1slow01Z71's Avatar
Pressure also helps with lubrication and Im running large oil tolernaces due to an extra long stroke crank and I just want to make sure the life blood of my engine is circulating well.
Old 01-14-2007, 12:21 PM
Irocss85's Avatar
I went with .100. well, actuall .104". you might want to go with the .150 though, since you have lager oil bearing tolerances to keep press. up at higher rpm.
Old 01-14-2007, 01:19 PM
JPH
JPH's Avatar
why don't use just buy a better pump. melling has a high volume/high pressure pump that works awesome in these motors. 15%+ more volume, and 10psi+ more pressure. melling #10296.
Old 01-14-2007, 05:27 PM
Irocss85's Avatar
in my case the oil pump comeing out of the car only has 6K miles on it. no need to replace it.
Old 01-14-2007, 05:38 PM
GuitsBoy's Avatar
I shimmed mine with three small aluminum washers from lowes. Togather they were over 1/8 but under 3/16 thick. I figure .150 is a good thickness to shoot for. I have 60+ psi cold idle, and 45+ psi hot idle.
Old 01-15-2007, 09:39 PM
00454sscamaro's Avatar
i ported my stocker and took the shimms out of my f'd up tsp pump got about 70psi at 500rpm's and havent really reved it much so cant tell you on the wot pressures.
edit: i also got rp 10w 30 in there so the pressure going to be a good bit higher then m1 10w 30 .
Old 01-16-2007, 12:33 PM
DRCE's Avatar
Pressure without volume means nothing. What are your clearances at?
65psi at 6600rpm is more than enough pressure.
Old 01-16-2007, 12:45 PM
Nasty N8's Avatar
Ya good rule is 10psi for every 1000rpm
Nate
Old 01-24-2007, 01:39 PM
NoMoreFWD's Avatar
I read W2W does .070".
Old 01-24-2007, 02:22 PM
LETHL_SS's Avatar
Mine is at .125. Just dont put too much or you wont have any oil pressure...... found that out the hard way.
Quick Reply: How much to shim oil pump?
