What heads do I need?
Old 12-05-2006, 03:06 PM
JuStIn_Ws6's Avatar
Default What heads do I need?
So I am wanted to purchase some new/used heads for my 2000 T/A. The problem is I'm not really sure what heads I should go with. I talked to a buddy of mine and he told me that if I wasn't thinking about doing forced induction later on down the road I wouldn't want any heads larger than 5.7 liters. Now I'm not really sure if I should go with 5.3 heads or 5.7 heads because of the compression ratios and which one I would get the most power out of. Also I am not sure what manufacturer to go with. I plan on going with a mild cam with the heads so any suggestion will help! Thanks in advance guys.
Old 12-05-2006, 03:21 PM
SiL3NtXWS6's Avatar
are you cammed yet..?
The question is too loaded to give a proper answer. If you want honest opinions, list goals, cam sizes, driveability concerns and etc.
Personally, i believe for a heads/cam car, you can't beat AFR 205cc heads. Pricey, but well worth it.
Old 12-05-2006, 04:01 PM
jpat1023's Avatar
Actually, it would help you even more if you did all this in the 'Internal Engine Section'.........Good Luck
Old 12-08-2006, 07:56 PM
JuStIn_Ws6's Avatar
anyone?
Old 12-08-2006, 09:39 PM
99blancoSS's Avatar
Way to many threads posted on this subject to not have a better idea of what you want. Do some reading and help yourself.
Old 12-08-2006, 10:32 PM
peterbuiltss's Avatar
id go with LS6 heads not only will they improve HP but they are excellent up grade as long as you dont have anything else done
