Copper Spray Stock Head Gaskets?
Old 12-20-2006, 01:46 PM
Ferocity02's Avatar
Default Copper Spray Stock Head Gaskets?
I was just curious if this is necessary, or a good idea? That's all, thanks!
Old 12-20-2006, 02:53 PM
Closed ex-Sponsor Account
SteveDoten@ARH's Avatar
I've never done it
I'd like to know where this idea comes from?
Old 12-20-2006, 03:20 PM
lt1formula2000's Avatar
I sprayed some on mine, and I haven't had any problems. I did it because I had a can(spray can,not bottle/brush) laying around, from a couple 5.0 builds we did.
Old 12-20-2006, 03:44 PM
KingSS's Avatar
Just another way to provide some extra seal. I think some people do it on MLS gaskets just to make sure they seal correctly on the whole deck surface.
Old 12-20-2006, 06:50 PM
Ferocity02's Avatar
The reason I asked is because the stock gaskets are of a different material and appear to be much softer than the aftermarket MLS gaskets out there. I have a can of copper spray lying around so I guess I'll use it, it worked great with my Cometics.
Old 12-20-2006, 09:22 PM
DanZ28's Avatar
Never used it either. All my gaskets have done there job, but if you have some imperfections on the head or block deck, probably not a bad idea to spray some on there.
Dan
Old 12-21-2006, 08:30 AM
allngn_c5's Avatar
I guess I'll be spraying my Cometics when they get put on in March. The first set without spray wouldn't seal so GM Performance were used and they failed after about 4000 miles or so. 2800 + relatively hard driving miles. LOL, you've seen my vids ....
Old 12-21-2006, 08:34 AM
SideStep's Avatar
Steel or composite gaskets???
I have always spray copper sealant on my steel gaskets (Cometics) and have not had a leak yet....
Old 12-21-2006, 02:47 PM
Mikey 97Z M6's Avatar
Back when I had my DSM, some of those guys swore by that stuff when running over 17psi boost. Helped in the prevention of pushing oil into the coolant @ boost. I used it on my DSM when I replaced the head gasket, and it worked great at 17psi on pump fuel. BTW, I was using a MLS gasket on my DSM when I used that copper spray......
Don't know of anyone that has used it on an LSx though.....
Mike
Old 12-21-2006, 04:55 PM
GuitsBoy's Avatar
The GM MLS gaskets already have a black viton rubber coating. I didnt bother spraying copper on mine.
Old 12-21-2006, 08:37 PM
ArcticZ28's Avatar
Spraying the stock gaskets would be a bit of overkill. The only reason I ever use copper spray is for my cometics, and that's just to play it safe. A lot of people don't spray them and they still seal like a charm.
Old 12-21-2006, 08:38 PM
Ferocity02's Avatar
I mounted the heads about 30 minutes ago with copper spray on the gaskets. If they leak then I will probably shoot myself.
Old 12-21-2006, 08:43 PM
ArcticZ28's Avatar
Haha, there's no way those things are going to... don't mean to jinx ya though
Old 12-21-2006, 09:59 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
it wont leak we used that spray on copper gaskets on a blown stang before and no leaks.
Old 12-22-2006, 02:08 AM
1320 killer's Avatar
Not too sure but from what I was told is that it is good to use on a mls gasket and anything more than 11 to 1 compression. I used it on mine and it is holding pretty well (knock on wood)
Old 12-22-2006, 05:41 AM
LS1MCSS's Avatar
What is the actual name of the copper spray and who makes it? I am swapping heads and cam this winter and plan on using cometics. My car isn't a dd but I don't want problems when I do drive it.
Old 12-22-2006, 08:27 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
I'm guessing it is a common thing found at any auto parts store. I'm going to be switching to cometics as well this winter and will spray them just to make sure everything works out as planned.
Old 12-22-2006, 10:22 AM
ArcticZ28's Avatar
Permatex makes it.
Old 12-27-2006, 09:11 PM
yep permatex any auto store should have it
Quick Reply: Copper Spray Stock Head Gaskets?
