lifter tick at idle after Hitting 6k rpms
Old 12-22-2006, 08:24 PM
mvvette97's Avatar
Default lifter tick at idle after Hitting 6k rpms
It does it at idle but if I rev it some it quits. It seems to do it at lower prms. I pulled the valve cover and looked at the springs "Patriot Golds" and they seem to be fine. No bent pushrods and no bad rockers. Any idea?
Old 12-22-2006, 11:19 PM
DJMRTS's Avatar
Could be a bad lifter. Make sure you have good oil pressure. Also could be piston slap.
Old 12-22-2006, 11:22 PM
mvvette97's Avatar
**** man, i hope not. My oil pressure is never below 40psi. I've been settin here reading about all these Futral cams going bad so I hope my Comp isn't doing the same thing
