CAM INSTALL: Can I use my oem sprockets w/ the LS2 chain?
Old 12-25-2006, 12:50 AM
Cobra4B's Avatar
Default CAM INSTALL: Can I use my oem sprockets w/ the LS2 chain?
Going to go w/ the LS2 chain and GM chain damper.... I've always assumed I just re-use my stock sprockets.... true?
Old 12-25-2006, 01:12 AM
DuronClocker's Avatar
I used mine stock sprockets with my LS2 chain without a problem. Should be fine as long as they aren't noticeably worn.
Old 12-25-2006, 10:11 PM
Cobra4B's Avatar
What do I look for as far as wear... not sure what to compare them to? Will the teeth be worn down etc if they're worn?
Car has over 68k on it now... many track and auto-x miles.
Old 12-26-2006, 07:57 AM
99blancoSS's Avatar
now is the time when we dance on sprokets
Your stocker should be fine. Just looked for rounded or broken teeth.
Old 12-26-2006, 08:33 AM
Cobra4B's Avatar
^ lol... "it's sprockets!" [/mike meyer's voice]
