Nitrous Cam?
Nitrous Cam?
Now that my other ls1 is gone I want a new project.
I wanted to know a fairly large camshaft to use with milled trickflow heads. Compression will be anywhere from 11.0-11.5:1. I don't care if I have to flycut and I'll be running up to a 250 shot. The cam has to be drivable enough to be daily driven eventhough the car will not be.
I like the way a TSP 233/239 and the G5x3 idles, or somewhere close. I'm more than willing to give a little on the idle for numbers. I want to make mid to high 400 in an auto, and have a tame enough stall to daily drive/work well with the nitrous.
Thanks in advance for input,
James
Sound clips of cams I can deal with
TTP V4 (My personal favorite)
G5X3 114LSA (ORY, Magnaflow, Dart Heads, untuned)
TSP 233/239 (TD's, Next favorite)
Normally I don't like this cam, but the smoothest T-Rex I've ever heard
G5X2 (Very Tame)
I normally don't like posting other peoples cars so if you want me to take yours down, just ask...
James
G5X2 (Very Tame)
James
G5X2 (Very Tame)
James
G5X2 (Very Tame)
Orangeappeal I believe runs a mid size nitrous cam and has been some pretty good times... 224/230 I believe? Just throwing it out there maybe he'll chime in.
that cam on a 114 will sound good. i just had crane cut me a 224/228 on a 114, and it sounds pretty good in a customers car. go to ls1sounds.com, in the cam section, i think there is a 224/228 on a 114 in there. if i had a sound clip, i would post it for you, but i don't. you might check vinci's website to.
