Dowel pins or Flywheel?
Old 01-05-2007, 04:37 PM
simple1's Avatar
Default Dowel pins or Flywheel?
Hey I am having a problem with my dowel pins fitting. I recieved them from the dealership but they are certainly not the correct ones for this flywheel. The size I need for the flywheel is : Diameter : .235" Length : .475". Please let me know if I have the incorrect flywheel or if I need different dowel pins. I would also need to know where to get the correct dowel pins. Thank you for your time.
Old 01-05-2007, 08:45 PM
Beast96Z's Avatar
The dowel pin is only there to help you get the bolts started into the crank. If you can get the flywheel up and bolted down without it, then you don't need it. There should only be one. You are talking about a LS1 right?
Quick Reply: Dowel pins or Flywheel?
