Need Torque Cam Advice!
I recently sold my TR 224/224 that I had for over a year and never installed. Now, Im in the market for a cam similar to Patrick G's torque cam. I want something a little more aggresive (maybe in the 230s), since the car isnt a daily driver. I know it will be a custom grind, so please dont recommend an off the shelf cam. The car is an auto with a 2800 stall Vig converter. Also, a set of Comp 921s will be installed along with the cam, so the lift wont be too much of an issue. I dont know much about cams and the members of this board have answered all of my questions fully, so i figured it would be a good place to start. Hopefully Patrick will chime in on this one! Thanks guys!
LS1 Tech Administrator
If you're not opposed to lift and plan on shimming your 921s, you can run LSK lobes without issue. A 2800 stall might limit the amount of duration you can run. Do you have a cutout with your MAC headers or is it just a catback? Bringing up dynamic compression is going to be a major issue to give you the mid-range punch you're looking for.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
With a lumpy torque cam, you will hate that Loud Mouth exhaust, and I would highly recommend long tube headers and a 3,000 stall converter first.
What gears do you have?
Im going to do the 402 this fall, so I can enjoy my car in the spring and summer and dont have it sitting at a shop for a month or more waiting on everything to go in. Nothing like t-tops on a sunny day to make you feel good!
As far as I know, you dont have to get a ridiculous sized cam to go with big cubes. This car might see the track less than 10 times a year once it has the 402. The rest of the time it will be on the street cruising around. I want a cam for right now so I can have something to play with this summer. If i have to get another one for the 402, then I'll get it once I buy the block.
I too, recommend waiting, but if you must.... I think the cam I have would work well in your application. It's a Crane "Z" cam that specs at 228/232 @112+5. In my LS6 with stock GM MLS gaskets, and 61cc heads, I get 10.95 SCR, and 8.55 DCR, and the midrange is incredible. It'll still pull hard to redline, and idles pretty good, too.
Then save the money for a new cam now and put it toward good long tube headers for the 402. There is no sense in swaping cams now and then doing it again in 9-10 months. If you can afford to change cams twice in one year, you can afford long tube headers.
Ok, let me say this one more time. I am looking for a noticeable power difference for THIS spring and summer. Im not worried about the 402 right now, that is a future project and Im focusing on the stock 346 for now. You are right, if I can afford to change cams twice in a year then I can afford long tube headers when I buy the 402. I dont want to buy them now and then scratch them up. This car isnt just a track car, I like it to look good too! Please everyone forget about the 402 for now! ! !
Does anyone know the ramp rates of the Crane cams? or more specifically how they compare to the LSK/XER Comp lobes? Because I like the looks of that Crane cam as well except for the LSA and advance.
Depending on how far into the 230's you mean, you're kind of moving away from 'torque cam' durations. Honestly, the 224 you had would have done exactly what you wanted for the time being.
Patrick's Torque Cam is a 224/228 LSK grind on a 110 LSA, installed straight up. Some keep referring to a 228/232 grind as his 'torque cam', and I suppose he must have spec'd it for someone who wanted a little more. Either one would serve you well, the latter trading a bit of low end (which you can afford with your stall) for some of the top end.
Also, if you plan to spin any of them over 6,000 you might want to start investing in some hard parts for your tranny.
Good Luck!
Good Luck!
You want a good 230 range try this:
231/240 .643/.608 112+4 OR 111+2 (A little meaner)
2128 LSK int and 3730 XE-R exht
That would fit under stock heads and is a good balance between trq and upper HP.
Good Luck!
Good Luck!
Well, restalling it to 3200 isnt something I really want to do. I have trouble hooking on the street with the stock stall, the 2800 will give me enough problems when I get it put in. I'm trying to stay low with the stall so I can try to get the car to hook on the street and unprepped tracks without slicks.
