Custom bore size Cometic head gaskets
Looking for opinions here...
The standard Bore opening size for Cometic MLS LS1/LS6 head gaskets is 3.910". The physical cylinder bore size by specification is 3.898". What is considered the safest minimum gasket opening size for the cylinder bore? I think I have heard of 3.903's. Can it even go tighter?
And yes, i realize chasing the tightest gasket opening to bore size is probably a waste of time, none the less, let's entertain this idea.
Hammer
Hammer
Originally Posted by brad8266
call cometic and ask about it, maybe they can hook it up somehow.
Hammer
Hammer
Hammer
Originally Posted by JPH
you must be really trying to squeeze all the compression out of this thing. i would use 3.910 and call it a day, .007 won't change enough to even notice. cometic will cut you anything you want.
Hammer
