Just bought a MS3, got a few questions??
I was wondering how much i can mill the stock 241 castings with a MS3 cam and when i mill the stock heads...What kind of gain can i expect from doing this? Also what is the major difference between the Ls2 timing chain and a double roller? what about the oil pump i have an 02 and might have an ls6 block...if so would i also have an ls6 oil pump or would it still be an ls1 because i know for sure i dont have an ls1 water pump because i went through that whole hassle when i got a thermostat for it...not sure if the original owner replaced it or if it came from the factory that way...thanks
