Can u fit a 90mm Fast TB on a LS6
Old 02-05-2007, 09:27 AM
peterbuiltss's Avatar
Default Can u fit a 90mm Fast TB on a LS6
not knowing as much as i want to know about LS1's but im learnig anyway can i fit a Fast 90mm TB on a LS6 intake or do Fast TB fit on only fast intakes, also whats the size TB spacing on a stock LS1 is it 75mm, or 78mm? im building a 2001 LS1 what is best to use for bolt-ons the LS2 intake or the LS6 intake remember just boltons
Old 02-05-2007, 09:29 AM
slt200mph's Avatar
TPIS can modify a LS6 intake to accept one of their 90 MM oval TBs. But you cannot bolt up a regualr round 90 MM TB like a Nick Williams to a LS6 intake.. I would suggest a LS6 and have your TB ported a polished the LS6 intake will flow better than the LS2 intake ... if you use a LS2 intake you will have to change out your fuel rails too.
Old 02-05-2007, 09:33 AM
2000TransAmWS6's Avatar
the LS6 intake manifold flows alittle better than the LS2, so you will be fine with a LS6. a 90 mm TB will only fit on the FAST 90mm intake manifolds and LS2 intake manifolds, and will not fit on the LS6 units.
for a bolt on car using a stock ported TB will be fine.
just so that you know, next time post intake manifold questions in the "External Engine" forum, you'll get more responses there.
