What is meant by "degree the camshaft"
Old 02-05-2007, 10:07 PM
Daredevil_TA's Avatar
Default What is meant by "degree the camshaft"
I heard somebody use this term to get some extra power but i didnt know what they meant by it, what is it an hows it done?
Old 02-05-2007, 10:17 PM
Ryan02SS's Avatar
The degree process allows you to verify the camshaft valve events are taking place as it should.
For ex.... A TR224 224/224 112LSA 108 ICL meaning it's +4 advanced. Installing this cam and lining up the crank and cam gear dots leaves you at the mercy that the cam was ground correctly. Degreeing the cam in at 108ICL and observing the valve events allows you to verify the cam is performing at max potential.
All the major companies sell Degree kits for $70-100. They come with everything you need and usually include a video. It seems hard at first but after you do one or two it's very simple and worth it.
Old 02-05-2007, 10:26 PM
david vericker's Avatar
Refer to the sticky "Cam Guide" it will tell you everything you need to know about installing a cam.
Old 02-05-2007, 10:37 PM
DONAIMIAN's Avatar
Yup, everything and then some.
Old 02-06-2007, 01:49 AM
speed_demon24's Avatar
It's not just the cam that throws it off too, its the timing chain set, and the machined key in the crankshaft.
Old 02-06-2007, 09:54 PM
whoops i forgot about that cam guide-i didnt even think to look at that, so pretty much when you "degree" a cam your just making sure the cam was ground to the right specs? makes sense, thanx guys
Old 02-06-2007, 11:17 PM
Read my post above yours, its not just checking the cam, the cam can be ground perfectly but if the timing chain set and crankshaft wasnt machined perfectly which they probably weren't then it won't matter how the cam was ground.
