Input...
Old 02-09-2007, 03:21 PM
BatmobileWS6's Avatar
Default Input...
First off, I have a 2000 trans am ws6, 6 speed with long tube headers, exhaust, air lid and 373 gears.
I am getting a cam (231 237 .589 .595 112??) and pulleys and belts installed soon.
In the future I plan on possibly heads, nitrous, supercharger, ect..
I was wondering since I already will have engine work being done...is there something I should do now, that may be needed later on...
What do you think about ported HV oil pump and double roller chain??
Thanks alot.
Old 02-09-2007, 03:37 PM
lt1formula2000's Avatar
i would at least get a oil pump and a LS2 timing chain since your already in there. If you are pulling the motor to do this I would also do ARP or katech rod bolts.
Old 02-09-2007, 04:17 PM
JPH
JPH's Avatar
Thanks alot.
nos/supercharger, grind that cam on a 114lsa, and upgrade to better oil pump, timing set, headgaskets and bolts.
Old 02-09-2007, 05:34 PM
So that cam wont work out later on if i decide to go with nitrious/supercharger?
Also, what exactly do I get out of a better oil pump...amd what is meant by better oil pump?
Thanks
