rocker arm adjustments???
I have recently recieved my Cranecams rocker arms and I would like to have some advice on adjustments when installing. I have listened to several people and some say torque them to 22 lbs. others say they need adjustments??? Please help I would like to start with the cam and rocker upgrade soon. Thanks
It depends on what rocker kit u got, is it the adjustables or is it the factory mount type? If it is factory type then yes torque to 22ftlbs if it is the adj. then i dont know! i am trying to find out the correct adjustments for the comp pro magnum rockers that i just bought but it seems nobody else knows either! Myaybe somebody will respond!
Di you purchase just the rockers or is it the full kit with studs, guideplates and pushrods? (part # 144759-16). You need all the parts of this part # to make the rockers work. Some parts places don't understand this and just sell the 144759A-16 which is incomplete for install. Here is a link to the adjustment procedure.
http://www.vincihighperformance.com/...TRUCTIONS.HTML
Crane Gold Adjustable Rockers Noise?
I installed the complete "kit" of the Crane Gold 1.8 ratios. At first start-up & first couple hours of street run time, most just around town city traffic with a few first gear high RPM runs, all was noise-less. Now I am getting, what seems like, some rocker noise. Nothing radical, like all of them are making noise, maybe just a couple of them? It is the same whether hot or cold running. Anyone ever have this situation? Do these rockers have to be babysat? Thanks for anyone elses experience & input. Gar
When you first start the engine after the installation it's probably going to be very noisy for the first couple of minutes. Don't panic. It will gradually become quieter until the clatter subsides. That's if you have the preload set correctly. If the lifters are OEM you go about 1/2 to 3/4 of a turn after zero lash. You stop at zero when using Comp Rs.
agree with above. follow the instructions to a t. the vast majority of issues come from too much initial pre-load. zero is that, no lash. it is very easy to go beyond zero lash and unknowingly load the lifter.
