places to get ls1 heads ported
It's usually worth it to send them out to someone that know's LS1 heads. Unless of course you want to try your hand at it. Give Patriot Performance a call. They'll probably CNC port them for you for as good a price as you'd get locally.
Originally Posted by transamfreak01
is it even worth it to get them ported? i would think spend a little more cash and get something else
What exactly makes the LS6 head so special? Wouldn't it have the same type of casting as a LS1 head, only milled a little more with a small difference in port size??
Looks to me like you could take a 241 head, have it milled to achieve 10:5.1 CR and do some mild port work to get the same results. Doesn't the LS6 have the same size valves too?
