please help-how much to mill-tsp torquer 2
Old 02-21-2007, 11:53 AM
ls2 bait's Avatar
Default please help-how much to mill-tsp torquer 2
off the shelf tsp torquer v.2 on a 112. how much if any can a stock 99 ls1 head be milled while running a .040 gasket? with no flycutting btw.
Old 02-23-2007, 10:30 PM
ls2 bait's Avatar
anyone have a clue? maybe tsp can chime in here?
Old 02-24-2007, 05:31 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I would call them up. They can atleast tell you what it is with a stock MLS or possibly a cometic gasket. I would imagine that you probably could go up to about .020 and still play it safe. Mine are milled .020 on my 244/248 .598/.598 115 cam with no reliefs. I didn't check PTV, but the cam is performing great and has been in the car almost 15k miles. I am sure it is close on tolerance, but I just used a stock head gasket.
Old 02-24-2007, 11:56 AM
ls2 bait's Avatar
i may have to call them. ive tried to email them but im sure they have tons of email so i =ve never had good luck with that.
Old 02-24-2007, 02:10 PM
Chris Gage's Avatar
Call and talk to Trevor..... ask about specific mill and gasket combo to better help you.
Old 02-25-2007, 01:41 PM
Phil'sC5vette's Avatar
Id be interested to.
I called them about that cam and the AFR heads milled .020 off with the GM gasket, and im pretty sure they said yes
Old 02-25-2007, 02:28 PM
ls2 bait's Avatar
well i know how far i can mill the heads i want to get to stock i just need to know how much further i can go. gotta get some compression in this puppy.
Old 02-26-2007, 10:30 AM
ls2 bait's Avatar
t.t.t.
Old 02-26-2007, 06:54 PM
GuitsBoy's Avatar
Without notching, youre playing russian roulette by milling at all with that gasket. TSP told me they didnt want to mill past .015 with that cam and stock gasket.
Old 02-26-2007, 08:11 PM
ls2 bait's Avatar
honestly ill be happy if i can just run that gasket and be in the safe margin. now if someone would decide whether or not the stock gasket is .053 or .060 compressed ill be a lot happier. because if its .060 then this gasket isnt going to work if they could only mil .015 on a stock one. but .053 is feasable
Old 02-26-2007, 08:22 PM
GuitsBoy's Avatar
The 5.7 MLS gaskets were rathed at .060 from the factory, but used ones typically mic out to about .053 - .055. Stock graphite gaskets were always .053 so no discrepancy there. I think youll do okay with those gaskets and no mill.
Old 03-17-2007, 05:56 AM
