Which Valve Springs?
Ive got 100k on the car now and was thinking about replacing the valve springs. I was thinking about the 918's. Car will eventually get a mid 230's camshaft, and then later on get heads at which point i will get dual valve springs.
So are those good for stock replacement? Any other recommendations?
i think 918 would be ok for a mid 230 cam with 1.7 rockers, but if i were you i would do the entire head swap at once and save on a 918 spring kit.
Im looking at the 233/239, which is just a hair over 600, its 605 i believe.
So basically im trying to find a spring that will handle a 233/239, but also be ok on my stock application until i get the cam
Originally Posted by vettenuts
The 918's will put a lot more load on your tired timing chain, but that's just my opinion.
Originally Posted by 00BlueTA
This is true, but if your doing a cam swap you should change the timing chain as well. I would put the patriot gold springs in and call it a day. They are the best spring for the money IMO, and they hold a .650 lift. They 918 are only good to .600 and that pushing it.
I thought about the ZO6 kit, but then when i got a cam i would have to change them again to something that could handle .600 lift a little better. When i do put in the cam i will be upgrading the timing chain and oil pump and all that other good stuff, just cant afford it right now.
Thats why i was trying to feel out if the 918's would be suitable to run while i was stock as well as once a mid 230's cam is installed, until i got heads with dual springs
Any other opinions?
Any other opinions?
Any other opinions?
Any other opinions?
Originally Posted by eamador11
If its not broken dont fix it. just wait till you do the cam instead.
So, back to my question about if they will work well in stock application as well as serve me for a while after i get a cam and until i get heads.
Because the stock springs blow and im over 100k and its time they be replaced. They see the redline every day, and im not sure how long its gonna be til i get a cam, let alone heads. Being in college sucks
If you are running a stock cam and you are a college student short on cash I am sure there are many people on LS1tech with stock low mile springs that would sell them very cheeply..or maybe even give them away free .. you can get yourself a set of PRC dual springs or patriot gold duals that will last a very long time..I have 43,000 miles on a set of PRC dual platinums..they don't cost much either..
If your stock springs are tired and you are short on cash, the $55 Z06 springs are the deal. They won't be much harder on your timing chain either. Then save your bucks for the final installation of the cam/springs you want. I wouldn't do the 918's on the tired stock LS1 timing chain myself.
LS2 timing chain is $28 ... Z06 springs are $55 for way less than $100 you can solve your problem..even a broke student can swing that deal ...
Well i dont really wanna strip the car down to the timing chain unless im gonna be putting in the cam at the same time.
So it sounds like the 918s would be a bit too much, so i guess im gonna go the ls6 springs, Does anybody have some, where were you finding them for $55??
