What engine oils to use ?
Old 03-06-2007, 11:05 PM
LS1IMPULSE's Avatar
Default What engine oils to use ?
I'm finally geting around to doing my cam swap and I am wondering if I should go with a thicker viscosity oil and what brand. It seems like Mobil 1 is the favorite, but alot of people like the German Castrol too.
Should I get the 0W-30 GC, 5/10W-30 Mobil, or one of the thicker 0/10W-40 oils I see some people using with bigger cams?
The cam being installed is the F14 (not highlift), and the temp around here now can be anywere from 5-30 degrees but the cars mostly sits in the garage in the winter and gets driven in the summer were temps are usually about 85 degrees and ocasionally there is a hot day around 95-100.
Old 03-07-2007, 11:05 AM
LS1IMPULSE's Avatar
no one has an opinion on the engine oils?
Old 03-07-2007, 11:15 AM
getusum's Avatar
here are about 50 ....https://ls1tech.com/forums/showthrea...ht=german+0-30....and if you needed some more info..
Old 03-07-2007, 09:33 PM
Joey7489's Avatar
German Castrol 0w30
Old 03-07-2007, 09:51 PM
marv's Avatar
Mobil 1 5W-30 for me...
Worked great so far...
Old 03-07-2007, 10:02 PM
405HP_Z06's Avatar
Pennzoil Platinum 10w-30
