Cam Selection
Cam Selection
Opinion question..Looking for some one to point me in the right direction....
I'm going to be running valve job/ported 243 heads..... It's 02 LS1...
Looking for a low duration high-lift cam for driveability reasons....
Looking for 226-228 Intake and 228-232ish exhaust side with around .600 lift for both....
Any recommendations??
street use?? easy pick
go tr224 563 112 or TSP 228r 588 113 bad *** cam
carteck grind a verey well balanced cam to, 228-230 590
i have expierince with tr224 114 it was perfect for my mods and drivibality too i use the car every day noproblem so far.
good luck bro
good luck bro
good luck bro
good luck bro
The TSP 228R is the one I have been eyeing....Good to see someone mentioned it.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would say maybe a 224/230 .615/.635 113.
I have run a variation of that cam, and decided to try and go turbo...but that didnt work out, so I swapped again to the 244/248 which is far from what you are looking for.
But that 224/230 on a 114 is pretty stealthy. -1° overlap will still have some "lopiness" to it, but will be a good DD cam as well.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Which cam? The 224/230 .615/.635 113?
I just pulled some specs together. That would end up being a custom grind.
However......There is a 224/230 .581/.588 114.
That is the current cam that is in my Z28. Love it, can't keep tires on the car. It is pretty stout off idle really. Mine is set around 950'ish.
