Which is better on Nitrous car MS4 or TREX?
As the title says. I am looking for lots of NA horsepower (with a lot of top end because the car has a race weight of 2700-2800lbs) and even more Nitrous assisted horsepower, I will be spraying around a 250shot so which cam would work better to run the best times on the gas.
I am also open to other cam suggestions that may work better with nitrous. I know the TREX is OK with nitrous but usually only smaller amounts.
What LSA are you thinking on these cams?
In a nutshell the one that "bleeds" of the least from intake charge will respond the best. Heads and exhaust play a role in that as well.
