LS Engine running rough? CHECK THIS OUT..CRAZY BUT REAL!
Just wanted to give you guys a heads up...
The car was running like crap! I was what the fuc...? Maybe it was internal issue...maybe it was the tune? I could n't figure it out...and the car was running crazy leaness....pegging at 25 ..maxing out the computer...(the pcv valve was bad and letting the car run lean like crazy at part throttle..vibrating the car..it was terrible..) then I replaced the pcv valve and all was good but...the pcv was getting sucked into the tube that holds it and again....vaccuum leak?
I changed the bad 6 dollar pcv valve and the car ran awesome...and then it took a dump again... I was like WTF?????
Well the pcv valve was getting sucked into the black tube that holds it...and then the car was running rough as hell...Really bad! I thought for sure I fuc ed the motor....somewhere somehow...or it was the tune? or this or that....
Took all the fun out of driving the car...
So I made sure the pcv silver metal band stop was outside the black plastic...with a little silver showing between the two seperate black hoses...
Thats how the pcv is supposed to sit ..
I took a zip tie and put it around the socket portion of the black tube that holds the pcv valve and the cars running smooth as hell..
I've been all over the map with this dam driveability issue...
Thinking it was the motor...the rings...the tune...the....intake leaking?
It was the stupid pcv valve needing replacement and then needed to be set right so it wasn't sinking into the black hole of the tube completely..
The pcv needs to rest on the outer ring of the pcv valve and the black hose..
Just a heads up...
I wasted quite a few miles trying to figure this out..
Good luck...(its running that much better that I can't believe the difference with such a stupid cause)
The answer is sometimes in the simple details...
No ****
JB
(edit: Give me a photo of any c5 engine bay with the covers removed....on the passenger side and I'll be glad to make a few pointers so people can see what I'm talking about...
THIS HAS TO BE THE DUMBEST CAUSE OF A TERRIBLE DRIVABILITY ISSUE THAT I HAVE EVER EXPERIENCED...
The largest silver ring of the pcv valve needs to rest on the outer lip of the plastic boot that cups it....
Do that and the car doesn't lose vacuum...
Mine was getting sucked in and then it wasn't sitting right and it was causing a vacuum leak...
The car ran like **** till I set the pcv valve correctly in its holder...
This is the part number and photo that holds the pcv valve..I didn't buy this cause it was a hundred bucks...at the dealership yesterday...I just zip tied the pcv valve so it couldn't get sucked into the tube again...It works!
Search Results of Available Items
*Prices are Per Unit
Page 1: 1-1 of 1 items
GM PART # 12573109
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $98.93
OUR PRICE: $58.65
DESCRIPTION: TUBE
Just a heads up...
No ****
JB
GM PART # 12573109
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $98.93
OUR PRICE: $58.65
DESCRIPTION: TUBE
I'm really passes this thing along because I can't tell you guys how long I was chasing this thing...
I can't tell you how many really good mechanics looked at this car and didnt' spot it..
I 'm hoping any body down the road who experienced terrible driveability....maybe some weird vibrations going through the rpm band might do a search and see this thread..
I'm still laughing my @ss off at how HUGE a difference this made!
For the first time in a long time the cars running SMOOTH as silk...
Driveability is back to like it was when new...!
HTH
HTH
The car was so annoying to drive...I was getting ready to build a new motor!
I thought for sure for the longest time the motor was fuc'd!
Those vacuum leak issues can really cause crazy driveability problems....
Now the cars running awesome!
No new motor needed (right now anyway!)
Cha ching!
Cha ching!
Was your car ever having any problems holding an idle during startup? What about when you were driving down the road at around 45-55mph, were you getting any fluttering/hesitation under steady throttle or no throttle?
I don't know if I was getting fluttering/hestitation...cause wot was ok...and the driveability issues were sporatic....
I'd suggest changing it out and making sure its not too far into the tube ..
Its so simple....to do..
I'd like to see a picture of the engine bay that you were also asking for so I can get a better idea of what you're talking about. If no one posts up today, I'll get one on here this weekend.
Reason I ask the questions above, is because those are the problems I am having. If you had the same problems, maybe it could be my pcv, but I'm stock internal and you're not having the same problems from what I can tell. I'm glad you fixed your problem though, I'm still working on mine!
I dont have a working camera so shoot up a photo and I'll copy and mark it up and repost it.
I would recommend this because I bet its more common than any of us realize.
If you have a driveability problem that would be the first course of action..(may not work but for 2 minutes time and 6 bucks? I'd suggest ruling it out...)
HTH
HTH
See the black tube between the oil fill cap and the small pully ..Dead center in the photo. HTH
That black tube pulls apart at its widest part..
Thats where the pcv valve is located..
The PCV does cause very negative effects if not working correctly.
No I'm NOT sure...mine had a groove in there too...but the cars running better..
I guess I could go back to the inside groove and see if it gets worse?
I thought the groove was because the pcv valve got sucked in there once?..
Are you sure the groove is from the factory? and thats what its for?
Sorry guys..
Sorry guys..
Sorry guys..
Sorry guys..
I do notice a difference when I change the PCV valve, but it seems to wear out fast. I've relegated myself to changing it every oil change until I figure out something else.
Originally Posted by 405HP_Z06
The groove is positively there from the factory. IMHO, the PCV system on the Z06 is crap. It causes the intake to ingest copious amounts of oil that pools in the throttle body.
Here was the front.
Did you ever have any problems like the ones I was mentioning in post #6?? Would you think this could be cause by a bad PCV? This is what the BACK of my throttle body looked like when I removed it to clean this past weekend.
Here was the front.
Here was the front.
The picture of the back looks like the front of my throttle body. Before I installed the dual catch cans, I had a pool of oil in the throttle body that leaked between the TB and air bridge coupler.
What CAI and filter are you running? Vararam foam by chance?
Vararam B2, grey filter. I recently had bad idle issues to the point of my car continuously dying multiple times. Since then I have cleaned up my throttle body, cleaned the MAF, resealed my Vararam unit, and checked for vacuum leaks. The bad idle is gone, but I still have the low throttle stumbling/surging/bucking/hesitation...whatever you want to call it. I had this problem before any cleaning done. The only mods I have done to the car are the Vararam and long tubes with high flow cats. Both were installed last October with no issues until recently. The car has not been dyno tuned. Maybe an easy check would be this pcv valve...before I get into things like fuel pressure/fuel pump/injectors/etc.
