First Time I Go WOT in 6 months - Bent a Pushrod?
Old 03-24-2007, 12:43 AM
Custom4204's Avatar
Default First Time I Go WOT in 6 months - Bent a Pushrod?
Just finished doing the 500 mile break in on my rebuilt T56. Picked up a buddy and finally got to make some WOT passes. On the 2nd run, flashing SES, slightly noticeable power loss, car feels weak and surges under 1500 rpms, sounds like a combination of an exhaust leak & a spark plug wire missing. No way I came close to over revving it.
Scanned it - Cylinder 5 Misfire Detected.
Sound like the a bent pushrod to anyone? Any chance I'm lucky and this is only a spark plug/wire issue?
Old 03-24-2007, 01:01 AM
Tainted's Avatar
you could always pull the plug out and check the wire just in case then go from there ocne you rule those out.
Old 03-24-2007, 10:37 AM
Custom4204's Avatar
Just pulled #5 spark plug and wire, looked fine.
Reinstalled, still missed.
Swapped #5 spark plug and wire with #3 spark plug and wire, still misfiring on #5.
Well, at least I know which of the 8 it is...
Old 03-24-2007, 12:07 PM
JPH
JPH's Avatar
bad coil, or broken valve spring maybe?
Old 03-24-2007, 12:31 PM
Custom4204's Avatar
I think it seems far too loud to be a bad coil.
Valve spring might be the new theory. Just checked it out again, after I revved it up a couple hundred rpms, it almost seemed to quiet down go away for a few seconds, then it came back. Wouldn't a pushrod have a consistent tick all the time?
Old 03-28-2007, 08:23 PM
Custom4204's Avatar
Pushrod on #5 was the culprit.
