Could this be daily driveable?
Old 03-25-2007, 03:35 PM
texasheat's Avatar
Default Could this be daily driveable?
Would a cam with 11 degrees overlap at .050" and a 109 lsa (109 degree ICL) be daily driveable?
Old 03-25-2007, 03:39 PM
brad8266's Avatar
The LSA alone is irrevelant, its the overlap which is derived from the LSA and duration that is what mainly determines drivability.
11 degrees is fine for a daily driver. I have a 10 degree overlap cam and it drives around town like its stock just about with the exception of the idle.
Old 03-25-2007, 04:02 PM
texasheat's Avatar
Extensive tuning will be required I'm guessing!
Old 03-25-2007, 04:08 PM
brad8266's Avatar
I wouldnt say extensive, I guess tuned mine at first and it ran fine. Just pulled lots of fuel and added like 4-5 degrees of spark down low.
11 degrees of overlap isnt a lot compared to some of the large cam out there.
Old 03-25-2007, 04:35 PM
Studytime's Avatar
Yes, you could daily drive that.
Ben T.
Old 03-25-2007, 04:45 PM
edwardswb's Avatar
I can daily drive an old john deere tractor with no top and a missing wheel. Point being, you can daily drive anything depending on what you are willing to put up with.
Old 03-25-2007, 08:07 PM
pdd
pdd's Avatar
[QUOTE=edwardswb]I can daily drive an old john deere tractor with no top and a missing wheel. [quote]
oooo-id like to see that
