Guys running a 4.1" Crank.
Old 04-07-2007, 07:17 PM
Daniel_z28's Avatar
Default Guys running a 4.1" Crank.
For those running a 4.1 crank where are you getting your custom pistons from and how much more did they cost? Also does the rod length stay at 6.125?
Old 04-07-2007, 09:23 PM
Beast96Z's Avatar
4.185" stroke here. Erik from HKE and Brian Nutter at Wiesco worked together for the piston in my motor. Cost was about $200 more than a shelf piston. Rod legnth is still 6.125". Piston was designed with motor life in mind.
Old 04-08-2007, 12:46 AM
racer7088's Avatar
Arrow
It depends on what cylinders you are using and how long they are. Some like Beast96Zs are a little longer than the stock LS1 engines. Depending on sleeve length and application I have also used 6.200 long rods as well. Like he said also they cost 100.00-250.00 more depending on how custom the piston is basically as in dome, dish or flat top as well.
Old 04-08-2007, 10:13 AM
Daniel_z28's Avatar
It's an iron block, 4.03 bore. When i was first researching building a 418 I read a lot of people complainaing about piston skirt/ring wear with the longer stroke, is this because people were not buying the correct pistons or is this still an issue with the longer strokes?
Old 04-08-2007, 11:06 AM
racer7088's Avatar
Yes the pistons have to be made for that bore length.
