torque cam with stock heads
Partrick G's torque cam with stock heads
Is anyone running this setup? What kind of results have you had? It looks like it (224/228 .636/.639) would be best on 110+2 for DCR and valve events with stock heads. Is this too much lift to gain any extra (compared to XER lobe) with just the stock LS6 manifold? Any input would be appreciated. Sorry, my forum search wasn't working tonight for some reason...
Torque coming out of my EARS! (cam change)
post #47 & post # 48
Originally Posted by 01SSRMS
Nice read Patrick, kinda changing my mind on future plans. Do you run aftermarket lifters with the lobes being so aggressive? Also, what would you think of running that cam on stock heads? Thanks for the info.
Originally Posted by Patrick G
I run stock lifters with stock rockers. I think this cam would work great with stock heads provided you get the good springs (Comp 921s) and shim them to within .050" of coil bind.
Thanks for the input guys. I know Patrick G. has a good set of heads he runs with this cam. Yes, I read all 45 pages of that thread this last weekend...very interesting. I had a 228/232 XE-R cam in mind until I read this, then I thought maybe a little less duration and an LSK lobe would be the way to go. I know he says the "torque cam" would work well with stock heads, but I just wondered if anyone has tried it yet?
