rocker question
Old 04-30-2007, 09:56 AM
Streetracer361's Avatar
Default rocker question
Does anyone know what the lash on the rocker should be on a 224/224-581/581 on 112. I dont know what they should be set at. "how much play should they should have" Have a lot of valve train noise. Please help
Old 04-30-2007, 01:02 PM
RGKSR's Avatar
Default 22 ft lbs
The stock rockers get torqued to 22 ft lbs if I remember correctly.
Use a pushrod checker to check for the correct length if you have questions.
Are your heads milled, if not a 7.4 pushrod is probally correct. Gasket thinkness counts in the formula also.
Alot of LS1/6's sound like sewing machines with aftermarket cams. Mine was scary when I first started it but I got used to it.
Bob K.
Old 04-30-2007, 07:31 PM
I have stock heads and a cam with full bolt ons and long tubes and off road y pipe. But it sounds like a shushing sound. Like a exchuast leak, I dont think that the rockers are gaped right.
