How much can be milled?
Old 05-04-2007, 12:17 PM
ASkipper's Avatar
Default How much can be milled?
I have a chance to buy a used set of PRC LS6 stage 2.5 heads.The guy I am getting them from said he had them milled .030 before he put them on. I am wanting to run the Torquer v.2 cam with them. My question is how much can be milled off the LS6 stage 2.5 heads before I run into PTV clearance. I am not wanting to flycut the pistons because I want to spray N20.
Old 05-04-2007, 01:00 PM
Stroker2112's Avatar
Default PTV clearance
ASKipper,
I have 243s milled down to 62ccs, the TQv2 cam, pistons .010 out of the hole, and a .040 head gasket with no problems. I'd like to mill an extra 2ccs from my heads... but don't want to push my luck.
Stroker2112
ASKipper,
Stroker2112
Old 05-04-2007, 01:04 PM
PREDATOR-Z's Avatar
First of all on what LSA and Advance (ICL) is the cam.
Second of all if they are 230cc PRC LS6, I would pass on these, theheads are prawn to cracking. The later 227cc versions are better.
