colder thermostat....worth it??
They are also good A4s for helping keep tranny temps down when you have a big stall since the fans run more and the fluid going to your cooler starts out at a lower temp..
I have a 160 T-Stat but use fan settings closer to a 180 T-stat.
I am with you sir..GM designed these motors to run hot...
Having a 160 stat doesn't mean that your motor is at 160 temp. It just means that coolant will flow through motor when 160 stat opens.
I'm in very hot area with A4, 160 stat and fans at 180. Temp stays nice and steady.
hell yeah its hot there! I landed there when I was leaving Qatar. That is the hottest muggy place I have ever been.
I disagree.....Emissions dictated GM ran them hot. If they wanted to "run hot" why would letting the car cool down at the track or on the dyno....make more power? An engine is an engine, and heat is the enemy. If I could I would run the oil at temp, and run the engine as cold as physically possible.
