Problems with idle!!
My car is having an occassional problem holding idle when I come to a stop. I have a 612 lift cam which I assume contributes to that partially but if I feather the throttle a little it comes back up to normal idle. It just wants to die out like its not getting any air or fuel.
Any suggestions??
Any suggestions??
Do you know what he changed for that? I called GForce this morning and they recommended that I check my throttle body to see if there is a little hole in the plate for air to pass when idleing. As if it is getting choked off when I let off of it.
