Need SDPC double timing chain help!!!!
Re: Need SDPC double timing chain help!!!!
Either one works well. However,in my opinion, the Torrington is overkill.
FYI, the Torrington bearing model is machined for an axial thrust bearing(Torrington).
Senior Member
Why overkill? Its only $20 more. Better to have too much than not enough.. right?! <img src="https://ls1tech.com/threads/images/graemlins/grin.gif" alt="" />
Senior Member
Thanks Ryan... I was going to get it anyways. I just didnt know if there were any problems with them or that you could put one on a LS1/6 with out modification to the block.
