anyone have MTI custom grind a cam?
Old 05-14-2007, 10:48 AM
SVTlightning87's Avatar
Default anyone have MTI custom grind a cam?
i think there X1 is a good cam but i want alittle more but some dont like the R1, has anyone had MTI grind them a cam?
Old 05-14-2007, 11:11 AM
PREDATOR-Z's Avatar
MTI is not as famous as they used to be. Some of their grinds are considered "Old School" compared to advances made in the past 2 years by other shops.
Still some good grinds though.
Some forgotten ones like B1 and T1 are still favorites in their power range area.
X1 with Stage 2E heads make for some fast combos (Wilwaxu)
Old 05-14-2007, 04:24 PM
thats what i hear, but if i had one custom ground would it make any difference? one more to what im looking for
Old 05-14-2007, 04:32 PM
vidal77boxing's Avatar
im putting in a MTI C2 with a 114lsa. will post dyno numbers as soon as i get the tune.
Old 05-14-2007, 05:18 PM
00T\A's Avatar
I've been running my B-1 for a long time with no plans to change it.
Not untill i get my new TFS 215's
Old 05-14-2007, 05:36 PM
jimmypop13's Avatar
why not use Patrick G's cam service? He will spec you a cam that does exactly what you want it to do
Old 05-14-2007, 05:37 PM
Zach@MTI's Avatar
We still believe in smaller-medium sized cams as opposed to the other shops that think that the largest cam with the big peak number is the best setup. The large peak number might sell the camshaft, but the right setup will outperform and that is what we are about. I've seen countless 224 cam setups out run huge cam cars out peak powering the setup by 25hp. It's all about the setup and as you said, the X1 and stage 2E cylinder head combination has made very consistant numbers with excellent torque curves.
Give us a call and we will get you set up with the RIGHT combination or at the very least grind whatever camshaft you would like.
Zach White
Sales Manager
Motorsport Technologies, Inc
281-870-8787
zachw@motorsporttech.com
Old 05-14-2007, 07:41 PM
TXZ28LS1's Avatar
thats what makes it a tough choice. mti has been established probably longer than any of these other shops. if they were so outdated, they wouldnt be around anymore. i know i was looking into one of there head and cam setups, but keep getting all caught up with all these guys and these new huge peak number combos!! but just like what predator z said man, the mti 2e/x1 combo i think is a pretty stout combo.. maybe wilwaxu can fill us in on his feelings on mti and that setup. i think hes still running that same setup even with all the new stuff for us lsx guys!!
Old 05-15-2007, 09:49 AM
hows the X1 cam without heads?
Old 05-15-2007, 11:20 AM
PREDATOR-Z's Avatar
Zach White
Sales Manager
281-870-8787
Also customer service is really good and you guys stand behind your products. That is valuable asset.
BTW just to clarify, by "famous" I meant involved on this forum on a regular basis.
Old 05-15-2007, 03:29 PM
TroubledWine3's Avatar
LOL...right.
Anyways, most every shop will do a custom grind for you and what a lot of people forget is that a lot of cars with big cams are also at the strip all the time racing their car. I don't see a 224 anywhere near the top of the list on the cam-only record. Do I want a big cam? Hell no, I DD my car every day, but big cams have their solid place in the LS1 market. Just depends on what you use your's for.
I will say this, though, my buddy's untuned stock-headed 02 SS with X1 traps 118mph in a 6spd. with stock clutch, 10 bolt, and 3.42s. And that's with SLP LTs.
Old 05-16-2007, 04:36 PM
Vette-Red's Avatar
I had MTI grind me a 238/242 .609/.615 on a 111lsa and it runs great. Nice lope at idle, but the power comes on really high. With a straight through exhaust it was tough to start in first gear; I switched to the bb prt's from the bullets and it is much better now. I have an 04 vette w/ a 6 speed. Uncorrected numbers were 431hp and 399tq. Now I just need to know what heads would best suit my setup?
