LS2 Timing Chain in LS1 ok right??
While doing a cam install in my LS1(66,000 miles), several people sugested I should replace my original timing chain with an LS2 chain, and that the stock LS1 sprockets would be fine. I contacted TSP about the LS2 chain compatibilty, and whoever I spoke to said, "uh yea, it should work." I didn't feel very reassured by his answer so I'd like to know the truth...
While you can use the LS2 on stock LS1 sprockets, it is not a 100% perfect match.
There is some slack using stock gears and much less using LS2 unit.
You can get the whole gear set for ~$60
