Texas Giant / 408ci owners chime in!!!!
TSP owners,
HOw does your Texas Giant work/perform in your large Cubic Inch engine? I have a Trq2 right now...want something to work well with new SSI/BBK LS1 intake w/85mm TB...milled 243 heads with Patriot porting....everything else is forged and ready to go.....
It's a Daily Driver...but have no prob putting the foot into it at a stop light confrontation....
Please advise...
Stroker2112
Please advise...
Stroker2112
Not to bash but Why would you have a LS1 intake on a 408? Also I would think the 243 heads arn`t big enough for a big 408! But back to your question. I had a cam very close to that in my 408 before. Loved it! I have a 250 255 640 640 112 now. SWEEEEET!
Thats exactly what I wanted to hear/read!!!...My initial project was somewhat derailed by the "home finance committee".... (know what I mean...). btw- the 243s are CNC'd...flow at 300cfm+ @.600 lift. So, looking for cam references from other 408ci owners and any other advice/consultation that will make my combo scream...
I'm thinking about the Texas Giant from TSP....
Stroker2112
Stroker2112
BeardWS6,
So what intake would you recommend for a 408?...I don't see that the FAST 78/90 is a big advantage over the SSi/BBK intake...In fact the only issue is heat as far as I can tell.....but I'll welcome your analysis (facts only please)...thanks
Stroker2112
Stroker2112
i'm pretty happy with my meager 244/248 considering i only have ported 243s also. an l92/76 setup puts up some great numbers if you can pick out a decent cam to match them and the combo is cheap.
Originally Posted by Stroker2112
BeardWS6,
Stroker2112
Stroker2112
Right on with the bigger head comment!..Budget is the only thing holding me back for awhile...have just enough for a cam.....so the Tex Giant should be right in the ball park for my set-up.... my dual springs are setup for .650 and the 243s flow best (300+cfm) at .600 too... so really anything with a lift at or above .600 would be perfect I think...
Any tips on the LSA?...
I think a 114 +4 will keep my IVC event at an acceptable ptv clearance...I have no problems right now with the Trq2 on a 113+2....040 gaskets, and Intake Valve closes - IVC 71.5 47 7.5 ABDC
my heads have 2cc reliefs...so would I need really need the +4 advance ?
What about duration?....is longer better here?....my stall is a VIG 3000 w/3.73 gears...I really just want to have a fast DD and go to the track a couple times...I appreciate all and any advice/consultation...
Stroker2112
Stroker2112
