Need Help Deciding on Heads for Torquer 2 Cam
Old 05-20-2007, 02:20 AM
Summit2345's Avatar
Default Need Help Deciding on Heads for Torquer 2 Cam
I need help on what heads I can run to make the car faster. I can rape most cars 1 & 2 gear but after that my buddy's STOCK 99 LS1 Camaro can stay beside me, and I mean all stock except a lid and cat back. I have looked at many different heads, but I want real world comparison of heads with this cam.
Mods:
Torquer 2 232/234, .595"/.598" 112lsa
Header's
Ory
GMMG
LS6 Intake
4.10
Any help would be greatly appreciated
Thanks, Joe
Old 05-20-2007, 03:19 AM
Ws6man2000's Avatar
Location: Ft lewis,Ft sill and thats all i hope.Katy texas
what do you have done suspension wise???? that cam makes power mid and up top you should be pulling away correct me if i am wrong anyone
Old 05-20-2007, 07:45 AM
PBMFIsMe's Avatar
I vote TSP 5.3L Stage 2.5 heads or TSP or Livernois CNC's LS2/LS6 heads.
Absolutely the best bang for the buck....and tons of guys making 400+ rwhp on that combo with supporting mods.
Old 05-20-2007, 08:16 AM
onebadZ28's Avatar
Livernois
Old 05-20-2007, 12:09 PM
Summit2345's Avatar
nothing its all stock suspension. We even raced from a 50mph roll and I only pulled a half a car on him
Old 05-20-2007, 09:55 PM
Summit2345's Avatar
nobody else???
Old 05-21-2007, 01:44 PM
Bad Blu Formula's Avatar
Either your friend is spraying or you just suck at driving. j/k On the top end, I believe your friend can keep up due to your 4.10 gears which suck for top end.
Old 05-21-2007, 02:10 PM
SSTowerman's Avatar
I have T2 and you are absolutely correct.
Old 05-21-2007, 02:18 PM
SSTowerman's Avatar
I've got it on good authority that the T2 with full boltons will make over 450rwhp with TSP LS6 2.5 stage heads. In fact, You'll need to get larger injectors to realize the full potential. That's on an M6 btw. While the 5.3s will raise your compression a bit, I don't believe they will out flow the afore mentioned heads. Still not a bad choice between the two for budget heads. Ofcourse AFR 205s are out there if money isn't an issue.
Old 05-21-2007, 02:22 PM
Summit2345's Avatar
thats the sad part his clutch is screwed up and he cant drive half as good as I can, so I need something to bring the power up
Old 05-21-2007, 02:42 PM
formula001's Avatar
Something doesn't sound right.. Was your car tuned after the cam install??
Old 05-21-2007, 04:36 PM
wag7079's Avatar
sure was tuned it runs great I thought until I raced my buddy in his stock ls1 now Im pissed off because its slow as a stock
edit this is summit, but Im on my buddys computer
Old 05-21-2007, 05:48 PM
Dave@LivernoisDSS's Avatar
Ive had quite a few guys run that comp grind with our heads with good results.
Old 05-22-2007, 03:31 AM
Bigbeach's Avatar
you have any dyno results
Old 05-22-2007, 10:01 AM
No, not off hand... it's rare for customers that didnt get the install done here to send me dyno graphs... even if they say they are going to. Ill see if I can dig up something.
Old 05-22-2007, 02:30 PM
Summit2345's Avatar
I would appreciate it!
Thanks, Joe
Old 05-23-2007, 09:41 AM
wag7079's Avatar
Clutch being screwed yea, but "I cant drive half as good as you" I don't really know about. lol. yea we were both just curious why I was keeping up? I'm not spraying, summit knows that we help each other with everything that is done to our cars lol!
Old 05-23-2007, 10:25 AM
sstony's Avatar
I was thinking about this combo--any clearance issues with this combo?? or i may just research a monster cam for these heads.
Old 05-23-2007, 10:29 AM
Kryckter's Avatar
I am going to vote for the PRC 5.3 heads. As long as you don't deck the head much more, you wont have and piston to valve clearance issues. Plus take a look in the dyno section, many combo's with the T2 cam and these heads are laying down around 450+ with all the supporting mods. Its a great setup!
Any depending what you mean by monster cam, but yes you will start running into tight clearances once you get above the mid 23x durations and .600+ lift cams. My ".234 ... .598" intake side cam had issues, but TSP can set it up for their MS3 to clear. Once you get into those size of cams though, you HAVE to check for the proper clearance.
Old 05-25-2007, 06:53 PM
wag7079's Avatar
Anymore opinions?
