need help w/ connectors at back of intake
okay - i'm not sure where else to post this thread, but i have 3 connectors on the wiring harness at the back of the intake.... i have the oil pressure sending unit, and two others that are almost identical... one is black, one is grey...
i know one goes on the back of the intake... but where does the other one go!?!?!?
i've done this stuff before, but can not for the life of me remember.
it's a little closer to the passenger side, than the driver's side if that helps.
thanks a ton in advance.
okay - so there's the cam sensor on the top/back of the block, then the map sensor which hangs off the back of the intake... and those two connectors are nearly identical in size and shape right???
i know the oil pres sending unit is a lighter circular connector, so i wasn't confused about that.
THANKS GUYS!!!
THANKS GUYS!!!
