question about a ticking sound
Old 05-23-2007, 10:27 PM
fuseone's Avatar
Default question about a ticking sound
ok i have this ticking sound it comes from the left driver side of the engine. it is not present if the car is park and it doesnt tick if i rev the motor up from a stop. i did notice a little bit of lost oil pressure when the car has been running for a little while. heres a video of it. http://youtube.com/watch?v=dK_fQ_5NSNw . any one got a idea?
Old 05-23-2007, 10:40 PM
staringback05's Avatar
could be a rocker.....also could be a exhaust leak, but i doubt it considering the oil loss
Old 05-23-2007, 11:06 PM
fuseone's Avatar
well yea there is a slight exhaust leak but the ticking noise is not the sound that you hear on that clip. see some say it could be a lifter but i was also seeing what else it might be.
Old 05-23-2007, 11:36 PM
could be a lifter also....do you have any metal in the pan/on dipstick?
Old 05-23-2007, 11:37 PM
fuseone's Avatar
didnt check the pan yet
but i dont see any on the dip stick
Old 05-23-2007, 11:52 PM
well ticking internally can develop from all kinds of things....i mean if its a cam bearing or rod bearing, there will be metal....rockers will sometimes give off metal also....id try to single out the main area then if that cant be decided check your oil
Old 05-24-2007, 12:05 AM
fuseone's Avatar
well it has to be some where on the back left bank some
fuseone's Avatar
also it did throw a ses light.
Old 05-24-2007, 01:49 AM
what was the code?
Old 05-24-2007, 04:11 AM
cowboysfan's Avatar
Holy cow!!! if it sounds that loud in the car I could only imagine outside. you need to stop driving it and figure out if it's a spun bearing ot collapsed lifter. that sound like a knock not a tap, could be a loud tap which then I would look at lifters if kinda of a knocking sound then probably spun bearing... man I feel it!!!!
Old 05-24-2007, 10:31 AM
fuseone's Avatar
cowboy chill trust me its not a spun bearing. because if you didnt read i said its in the top end not the bottom end. and who said im driving the car any more. you are getting aheado of you're self here
Old 05-24-2007, 11:32 AM
melchoir's Avatar
That did not sound at all like an exhaust leak. That sounds like something is rattleing not ticking.
Old 05-24-2007, 11:43 AM
fuseone's Avatar
you say rattle i say tick thats just how i described the sound. but i wanna know why it would only make it while i drive the car. and not while the car is parked like if its parked and i rev the motor it dont make a sound. i put it on a lift and and put it in gear and gave it some gas still no sound only while the car is moving does it make the sound. like would the increase load of the car pulling its weight cause a sound to come out in the top end?
Old 05-24-2007, 03:35 PM
regardless of rpm range, theres a difference in load on the car when youve got it in drive and moving
Old 05-25-2007, 12:15 AM
fuseone's Avatar
yea thats what i was asking and what could cause a ticking sound in the head only when there is a load put on a car while moving?
Old 05-25-2007, 03:52 AM
cowboysfan's Avatar
alright I'm calm!!!! just kinda hard to assist thru the internet. check wheel bearing/ shock strut. motor/trans mounts. if it only happens when car is rolling then I would look at drive train. engine I would think it would do it all the time..... something to think about..
was listening to vid and noticed the "sound" kinda goes away there at the end then comes back before vid ends, are you shifting gears at that point or just letting of the gas pedal? is it an M6 or A4?
