G5 cam and which heads?
Old 04-30-2003, 08:13 AM
Glenn Ford's Avatar
Default G5 cam and which heads?
I have been hearing a lot of good things about Absolute and TEA heads.
I have my eyes on the G5 cam (emissions issues?) and was wondering if anyone knows what is a good set of heads to complement the G5?
Or maybe I shouldn't use the G5??
Thanks for any help!
Old 04-30-2003, 09:00 AM
LS1Tech Premium Sponsor
Trevor @ Texas Speed & Perf.'s Avatar
Default Re: G5 cam and which heads?
It depends on the RPM that your emissions testing is being done at. If it's at idle, then you could have some problems. If it's a rolling test that's done at around 2,000 RPM, then you should pass with flying colors. The majority of aftermarket cams clean up really well with a few RPM's. If you have LS1 Edit, you could always take the car in with a 1,200 RPM idle and see what happens. This is assuming that you have a set of good cats on the car, too.
Trevor
__________________
Old 04-30-2003, 10:36 AM
Glenn Ford's Avatar
In maryland you don't have any emission on-site. You drive up, they plug into your OBD II, download your on-board data, then you drive away with a pass or fail!
Thats it!
Anyway - I'm still looking for a good heads recommendation!
Thanks!
Old 04-30-2003, 12:23 PM
CamM's Avatar
Probably the best heads to go with the G5 cam would be ones that LG Motorsports sells in their head/cam package to maximize the HP/tq numbers.
I happen to have a freshened set of heads from LGM for sale that would be perfect with the G5, if you are interested.
Old 04-30-2003, 01:52 PM
Glenn Ford's Avatar
I am interested - sent you private message.
Still thinking of T.E.A. 5.3 Stage II or Absolute LS1 stage II, and Cartek Stage II+"M" cam.
So many choices - It drives me nuts trying to figure out what is a rock solid winner. (not necessarily the most HP, just quality work and a good solid car)
So CamM - check your private msgs!
Old 04-30-2003, 04:43 PM
CamM's Avatar
Glenn - Sent you a PM back
Old 05-01-2003, 11:43 AM
TEA Brent's Avatar
Glen if you want to dicuss a set of heads you can call or private message me. Hope we can help you out.
