PVC Oil Catch Can Problem
Old 06-09-2007, 06:22 PM
mhoglund's Avatar
Default PVC Oil Catch Can Problem
I bought and had installed the Elite Engineering pvc oil catch can. Before the install I was getting 17 mpg's. Now after the install I'm only getting 15 mpg's. I tried resetting the computer but it didn't help. At wide open throttle my O2's are reading in the 920's which would indicate a rich condition. I know most of you don't even look at your O2's, but I don't have a wide band. There are no codes being thrown. Since the install the car feels a lot different, in a bad way. Does anyone have any suggestions?
Thanks,
Matt
Old 06-09-2007, 06:32 PM
99blancoSS's Avatar
see5 has a nice setup I'll find the post and post it for you.
https://ls1tech.com/forums/generation-iv-external-engine/691509-breathers-pcv-bypass-etc.html
I went to this setup and all seems fine right now.
Old 06-09-2007, 08:49 PM
mhoglund's Avatar
https://ls1tech.com/forums/showthread.php?t=691509
The one I have I think is ok. But why would it make my car run richer?
