Thinking about a bigger cam
I have a Comp 232/236 595/601 112 +4 XER lobe. I really like this cam, but I am thinking about getting a bigger cam. I have Patriot CNC ported 243 castings along with Patriot Gold springs. I am spraying a little nitrous now, but I am not going to spray over 150 on it. The car has a 3500 stall in it right now. I made 403 with the cam I have right now(cam only). I don't want to deal with fly cutting the pistons and I am going to take the heads off this winter to have them hand ported and have the bigger valves put in. I am running stock valves right now.
What would you do..........stay with the cam I have now or go bigger. If I went bigger I would like to have a cam that made good low end torque. I don't want a cam that just makes good power at high rpm's.
What cam would you recomend if I wanted to go bigger??
Thanks
Thanks
Stay with that cam. Even with my cam cars with smaller can keep up just as well. Its not worth it. Sounds like you have a great setup now,dont ruin it for 10 extra horses at 6800rpm.
i swapped from a tsp 231/237 cam and patriot 5.3l heads to an ms4 cam custom ground on a 110+4lsa and fast 90/90 with the same heads and picked up 60rwhp. Went from 410rwhp on a mustang dyno to 468rwhp. I havent been on a dynojet with the new combo but when i made 410 on the mustang i did 443 on a dynojet.
The thing is too i gained everywhere averaging 20-30 hp and torque from about 2500rpms up to 60hp and at 6600rpms. here is a link to the graph of just my gains from the swap.
http://good-times.webshots.com/photo...80052551wvSvGh
and a link to the one graph laid over the other
http://good-times.webshots.com/photo...80052551vywxMo
The driving characteristics of my ms4 on a 110lsa are just as good as the driving characteristics of my 231/237 cam i had on a 112lsa. I also have patriot 5.3l heads with 2.02 and 1.57 valves but the cam clears on my car since i have diamond forged pistons with -2cc valve reliefs
