ls6 questions
Old 06-18-2007, 06:54 PM
camaro_ss_97's Avatar
Default ls6 questions
ok i have a 97 ss and have an ls6 block and ls6 intake and i have stock ls1 heads longtubes what kinda power should i be seeing once i have everything together and would it be better for me to save $ and buy ls6 heads or send those ls1 heads off to a shop to get worked? i really would like to see 450hp at the rear wheels and i was thinking of either the ms3 cam or ms4 witch would be a better cam? thanks for the advise
Old 06-18-2007, 07:09 PM
transamfreak01's Avatar
yeah go with the ms4.. first though b4 the cam do a stall. yank ss4000 and then ms4 and then i would go with ls6 heads or maybe a step up. porting the stock ls1 heads will cost as much as a decent set of heads. youll be around your mark i think
Old 06-18-2007, 10:39 PM
ls6 heads and ms4 cam i should not waste my money on rockers will the stock 1.7 be ok
Old 06-19-2007, 02:16 PM
black01_WS6's Avatar
use the stock rockers they are fine.
ls6 heads and a ms4 should put you in the 450 range for sure if you were a m6. With your auto it may be hard to do. Dyno numbers for a auto really don't mean much.
You will be happy with the set up, and it will be pretty dam fast.
Old 06-19-2007, 08:11 PM
ok another question i just bought a tubular k-member now what of my old lt1 suspension can i use??
Old 06-20-2007, 04:59 PM
anyone?
Old 06-20-2007, 05:03 PM
TheLS1Kid's Avatar
Definitely go with the LS6 heads. They flow much better.
On the K-member, I would assume you could still use your upper and lower control arms, but don't quote me on that.
Old 06-20-2007, 05:19 PM
lastcall190's Avatar
While the motor's out, throw some Katech rod bolts in there! Won't get any easier.
-J
Old 06-20-2007, 08:10 PM
yea i believe i can but just not to sure bout the rack and pinion set up
Old 06-20-2007, 09:50 PM
sroach20's Avatar
just get some patriot ls6 heads.
Old 06-21-2007, 07:39 AM
What Are The Flow Numbers On Stock Ls6 Heads?
Old 06-21-2007, 08:43 PM
anybody know where i can get a serpintine pully set up for an ls6?
Old 06-26-2007, 12:26 PM
alright found some ls6 brand new head for 400 bucks good deal??
Old 06-26-2007, 01:43 PM
voda1's Avatar
These heads http://www.patriot-performance.com/w...05234&DID=1225
with 59cc chambers.
See this: https://ls1tech.com/forums/generation-iii-internal-engine/732392-recipe-500-rwhp-heads-cam.html
Old 06-27-2007, 07:45 AM
IS THIS CORRECT?????
Up for auction is a set of heads from a 2004 GTO LS6 5.7 Liter V-8. These heads are casting 241 and are 10.6 compression ratio. These heads are in absolutely perfect condition. They have 5K miles on them. The original spark plugs have never been removed and all the valve train is still on
Old 06-27-2007, 10:29 AM
Superjoe's Avatar
The '04 GTO came with an LS1, not an LS6. While it probably had an LS6 block and/or intake manifold, it would not have had LS6 heads.
Old 06-27-2007, 04:37 PM
did the 04 gto come with the 350 or 400 horse engine and are these heads worth buying?
Old 06-27-2007, 06:09 PM
Superjoe's Avatar
Like I said, it came with the LS1, so it's the 350 not the 400. No the heads are not worth buying. Your sig says that you are transplanting an LS6 already. Pull those heads and have them done up by a sponsor, I recommend Patriot or Texas-Speed. If you do not already have LS6 heads for some reason, get them from either vendor already ported and polished.
