Aluminum or Tri-metal rod bearings?
Old 06-26-2007, 07:27 AM
mondayp's Avatar
Default Aluminum or Tri-metal rod bearings?
I want to replace my rod bearings. They show minimal wear, but they are cheap and already out. Clevite shows aluminum and tri-metal versions, with the aluminum slightly more expensive. Which should I get?
Old 06-27-2007, 08:04 PM
helicoil's Avatar
Default bearings
stock bearings are aluminum. Tri-metal bearings traditionally carry more load when measured in psi. Be aware alot of tri-metal bearings are considered high performance. These bearings will have more eccentricity than a stock bearing (clearance at the parting line). This will effect overall oil clearances, be sure and check them.
Depending on your goals, stock replacement bearings will adeqaute and easier.
Quick Reply: Aluminum or Tri-metal rod bearings?
