LS1 bolt size for engine stand
Guys with the search engine down on the site I havent been able to find this out. I know there was a post on here that told what bolt sizes and lengths to use when putting the ls1 on a stand. Does anyone know this info or have the link to the thread? Thanks in advance!!
The thread size is M10 x 1.5 but the length will depend on the particular engine stand you are using. Just add 20mm to the depth of the engine stand mounting arms for ample thread engagement.
Make sure to use washers under the bolt heads to avoid having the bolts pull through the arms of the stand.
Good luck!
Good luck!
