Correct way to remove rocker nut with polylock
What is the correct way to remove a rocker nut with a polylock? Is it by first loosing the polylock, then loosing the rocker nut, or is it to loosen the rocker nut first?
I've tried both ways. Polylock method usually results in broken allen head. The other way seems to back out the stud. Last time I didn't care as I was moving the studs to different heads. Guess I will wait and see if anyone has any sure fire methods. I have considered going away from adjustables because of this.
I followed the method of JPH and it came off (with quite a bit of effort). I had a loose rocker. I retightened it and now it's making a sort of "squeaking" sound. I guess the lifter is probably toast.
