What to expect from this cam
Old 07-21-2007, 09:23 AM
Dragkid1917's Avatar
Default What to expect from this cam
ho-kay so, i just got my Lt's on with the ory and the lm1, and, i just cant resist the fact that, it would sound 1001 times better with a nice cam. Having said that, the Magic stick 3 looks like its got some *****. What can i expect in terms of drivaility and preformance from this cam.
Old 07-21-2007, 09:27 AM
delsold's Avatar
ho-kay totally sweet..well the magic stick 3 would probably be a totally good choice...are you manual 6 speed or automatic 4 speed?
wtf mate
Old 07-21-2007, 09:53 AM
haha, A4, i know the rpm range on the MS3 is from about 2400 to 6800, with a peak at 6400. How hard is it gunne be to drive under that 2400 rpm range, and, how good for my 97k miles motor is it to set the limiter to 6900.
Old 07-21-2007, 10:42 AM
PREDATOR-Z's Avatar
Go with a smaller cam and before you cam get a stall and gears (especialy stall)
Cam only this is a good one for you 227/236 .639/.602 112+4 (Custom LSK/XE-R)
Stall Vig 3800 or SS4000
Old 07-21-2007, 11:31 AM
White_Ls1's Avatar
As PREDATOR-Z mentioned if you are going with a cam any cam you need a stall, and especially with a MagicStick you will need a big stall and gears. Ask yourself the tough questions about drivability especially if this is a daily driver. Good luck -Dave
Old 07-21-2007, 06:24 PM
actually, that cam menioned seemed pretty good, i was hoping to find that lift with a bit smaller duration then the magic stick 3 or 4. Im going to get gears, but a stall isnt in the near future at all, my dad wont let me spend money on this car, cuz im building a superstocker. Ill definitly check that cam out thoo
Old 07-21-2007, 06:29 PM
on second thought, i cant find it, can you show me the website where that series of cams is.
Old 07-22-2007, 12:59 AM
PREDATOR-Z's Avatar
This is a custom grind, not a off shelf
Old 07-22-2007, 07:19 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
lol, www.compcams.com and call to order custom grinds.
Old 07-22-2007, 10:40 AM
ooooh ok awsome... sounds good
Old 07-22-2007, 11:49 AM
The only thing with a custom cam, is, knowing the rpm range and things like that. What i really wanted to do was get a cam that was like 230/234 .630/.610 and something like a 112 LSA. Woud something like that be a problem?
Old 07-22-2007, 03:32 PM
rickyracer25's Avatar
A quick highjack of the thread... My MS4 hasn't been everything I had hope for and I'm thinking about re-doing my cam to something just like that(maybe you could discuss why such a high lsa) or the Patrick G torque cam what would be the result with cam only vs. with some tsp stage 2.5 5.3L heads, also how would these respond to a 150 shot
little info, M6, full bolt-ons,
Old 07-22-2007, 04:44 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Your cam only making nearly 420! What else did you hope for?!??
Old 07-22-2007, 05:16 PM
sure it did 417 but the car is getting walk by cars with smaller better set-up combos that have more average hp and torque through the rpm range.
Old 07-22-2007, 06:25 PM
can someone answer my cam question lol ( 230/234, .630/.610 112 LSA?)
Old 07-23-2007, 12:29 AM
PREDATOR-Z's Avatar
Ahhh, I love it when a big cam guy spills out the facts. Nice sharing the truth with us so poeple can see that big is not always better.
Cudos to you man.
Old 07-23-2007, 12:48 AM
well don't get me wrong there are some guys here that run this cam (ms3, ms4, t-rex, and other donkey dick cams ) and are getting the results that they are looking for with more bolt ons or bigger cubes (electric water pump, heads, etc) and what not but for me the car is slowly becoming the slowest cam only car in amarillo and that is not a good thing.
also to answer your questioni think that predatorz's cam and Patrick G's torque cam may be the answer however the cam you suggested would be ok to good, but when you are spending $400 of your money why go with good to ok when you can get the best. (cause then you have to look at doing it again like me hahaha)
Old 07-23-2007, 03:59 AM
PREDATOR-Z's Avatar
It is all about the power range desired. This has been hashed a million times.
BIG cams need more supporting mods to fully benefit from their potential.
A properly balanced custom cam will make use of the setup you have, like exhaust and gears, also lower durations and tighter LSA will increase midrange ower (below curve) not requiring huge stalls or iron clutches and steep gears.
That is where Patrick, myself and few others like to play with.
Basicaly dyno peak numbers are not what we look at, we look at optimising the combo to produce max output, we tailor the cam to the combo, not tailor the combo to the cam.
Old 07-23-2007, 05:39 PM
ok so then a cam like 228/230, .610/.600 112 LSA?
Old 07-24-2007, 01:21 AM
PREDATOR-Z's Avatar
That looks like a XFI grind, I like more exhaust split.
You could grind the one I mentionned on XFI lobes
