lifter help!
lifter help!
i am helping a buddy put new push rods in his 98 ls1... it has been quite some time since i have adjusted lifters on a small block. can anyone send me a link to a good write up on specifications and steps. something like a how to guide for refreshment... thanks
ls1's are a cake walk.. no real adjustment unless you have adj rockers. just slap in the new pushrods tighten down the rockers torque to 22 ft/lbs rotate engine check torque again.
if you want a write up go to ls1howto.com and look at the cam install guide.
later aaron
later aaron
