97-98 heads good or bad?
Old 08-13-2007, 02:21 PM
lss1's Avatar
Default 97-98 heads good or bad?
I have been doing alot of research and have an LS1 that I am swapping into my MonteCarlo SS. I have a question on 98 year cylinder heads. I know 97 and 98 heads are perimiter bolt heads but is that the only diffrence? It seems that the 97-98 year heads always sell for dirt cheap compared to 99-later. I need heads for the motor and an thinking of picking some of these heads up just to get the car together. I will be upgrading the motor in about a year or two anyway. Any input is appreciated.
Marco
Old 08-13-2007, 02:26 PM
19SS98's Avatar
from wat i know the 98 heads do not flow too good. the 241 or 243 on the 99 on up are the better ones. cause i know what you mean about the 98s goin cheaper. i have a buddy sellin some for like 100.00
Old 08-13-2007, 04:06 PM
Sideways240sx's Avatar
they do not flow as good as the later heads, but up against ls1 heads they wont be that big of a difference in hp wise. If there in decent shape, and cheap enough and you plan on upgrading soon, why not save yourself a little bit of money now.
Chris
Old 08-13-2007, 04:09 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Moving to internal
Old 08-13-2007, 04:49 PM
AutomagicLS1's Avatar
Youll have to run those damn graphite gaskets instead of the mls gaskets with 98 heads they have that notch on the deck of the heads
Old 08-14-2007, 07:53 AM
Gunnar@Patriot's Avatar
If you are going to swap the heads, spend the extra and go with a set of 243 castings. You will see better power gians than simply going to a later set of LS1 heads. We have some great pricing on new 243's. Give us a call if you have any questions.
