cam install questions
Old 08-24-2007, 02:31 AM
RunNE1's Avatar
Default cam install questions
After finding a bad/flattened lifter and the subsequent damaged cam lobe my hopes for a simple head gasket swap quickly died. Should I replace all my comp lifters, or just replace the damaged one? With ~80,000 miles on the lifters I figured it might be a better idea to swap in a set of LS7 lifters(would this be considered a downgrade?).
Thanks for any help...
Old 08-24-2007, 02:54 AM
speeddemongto's Avatar
swap in the ls7's
Old 08-24-2007, 06:21 AM
mr. Jones's Avatar
why not install the caddy race lifters? (all of them).
LS7 lifters are now the standard replacement.
Are you checking or changing the valve springs?
Old 08-24-2007, 11:58 AM
ls1leadfoot's Avatar
Ls7 Lifters For Sure......
Old 08-24-2007, 11:59 AM
RunNE1's Avatar
Trying to stick to a budget on this install. Yes, I am changing the valve springs. I actually purchased them before I found out the cam was toast.
Old 08-24-2007, 12:03 PM
blkbird's Avatar
Stick with the LS7 lifters then......
Old 08-24-2007, 05:11 PM
Dragkid1917's Avatar
i have comp cams replacment lifters for sale, there not LS7's but there also not built as a standard gm replacment part. I bought em cuz my dad told me when i do this job i could just take off the intake and change em, but, that doesnt work with an ls1 only the gen 1 and 2 blocks
