Cam Project to commence this weekend!
Old 08-28-2007, 10:14 AM
LS1Formula01's Avatar
Default Cam Project to commence this weekend!
Well either friday night when i get off work or first thing saturday morning, tear down will begin to install my new TR 224/224 .563/.563 112LSA. Talkin to a guy i see at car shows every once in a while, I'm goin to run the LS6/Z06 valvesprings with this cam. His 03 Z06 has a similar cam(TSPs 224XE) and still runs the yellow springs. While I'm at it an LS2 timing chain will be installed, already have a fresh oil pump, TR 7.400 pushrods and a complete set of new valve stem seals while i'm at it. I will try to take some pics through the process and get a video up of it's first start-up.
Old 08-28-2007, 01:20 PM
5_02ls1's Avatar
those springs are fine im using them with a similar cam......have fun its not as bad as others will tell you....took 2 evenings to do mine ,,,,but we also done rod bolts as well so the kmember had to come out......
Old 08-28-2007, 02:31 PM
todds87ss's Avatar
Good luck with those springs. I used them for a short period. 1 broke in the first 2 hours of runtime. That was with a low lift cam (.525). I have since put in crane duals. Much quieter.
Old 08-28-2007, 03:44 PM
todds87ss, you may have had low lift, but the ramp rate is what may have broke that spring.
